跳转到主内容
无法从失败的集群加入尝试中删除过时的条目
71
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用场景
  • ONTAP 9
  • Data ONTAP 8.x
  • MDV 审核(mdv_aud)卷
  • 已启用 SVM/Vserver 审核
问题描述
加入失败后、同一节点的第二个版本将以不同的名称添加到集群中。初始尝试仍会显示上一个节点为“缺少”和“不符合条件”。任何强制退出尝试都将失败,并显示以下任一内容:
 Error: command failed: [Job 30029] Job failed: Failed to disable cluster-scoped metadata volume support prior to remove-node operation. Reason: [Job 30030] Job failed: An error occurred in the reception and processing of the API reply from the appliance. Error: command failed: [Job 880010] Job failed: Failed to disable cluster-scoped metadata volume support before remove node operation. Reason: [Job 880011] Job failed: Failed to delete volume
New to NetApp?
