跳转到主内容
无法删除分区驱动器的所有权- ONTAP 9
12
Visibility:
Votes:
0
Category:
fas-systems<a>2009268882</a>
Specialty:
hw
Last Updated:
适用场景
  • ONTAP 9
  • 高级驱动器分区(ADP)
问题描述
无法删除已分区驱动器的所有权
Cluster::> disk removeowner -data true -disk 3.0.9
Warning: Disks may be automatically assigned to the node because the option "disk.auto_assign" is enabled. If the affected volumes are not offline, the disks might be automatically assigned during the remove owner operation, which would cause unexpected results. To verify that the volumes are offline, abort this command then run "volume show".
Do you want to continue? {y|n}: y
Error: command failed: Failed to remove the owner of disk "3.0.9". Reason: Ownership Remove request failed for disk 3.0.9.P1. Reason:Disk is sick disk copy target disk. Changing its owner may cause
aggregate or filer outage.
New to NetApp?
