跳转到主内容
新加入的ONTAP 节点在管理网关服务器重新启动时反复崩溃
6
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core<a>2009年284026</a>
Last Updated:
适用场景
  • ONTAP 9
  • 节点加入
问题描述
  • 新加入的ONTAP 节点无法完成集群加入操作、命令行会持续重置为以下内容:
The management gateway server restarted. Waiting to see if the connection can be reestablished
Aug 28 09:04:58 [Cluster01-03:spm.mgwd.process.exit:EMERGENCY]: Management Gateway (mgwd) subsystem with ID 2145 exited as a result of signal normal exit (0). The subsystem will attempt to restart.
The management gateway server restarted. Waiting to see if the connection can be reestablished.
  • 新节点显示在集群中、但运行状况不正常:
Cluster01::> cluster show
Node          Health  Eligibility
Cluster01-01      true   true
Cluster01-02      true   true
Cluster01-03      false   true
New to NetApp?
