跳转到主内容
由于互连已关闭、接管已禁用
54
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
适用场景
  • ONTAP 9
  • AFF/FAS型号
  • HA 互连
问题描述
  • 收到警报、指出由于互连链路关闭、无法执行接管
[Node-01: cf_main: cf.fsm.takeoverOfPartnerDisabled:error]: Failover monitor: takeover of Node-01 disabled (HA interconnect error. Verify that the partner node is running and that the HA interconnect cabling is correct, if applicable. For further assistance, contact technical support).
  • 互连端口链路已关闭或已关闭
[Node1: gop_eq: ic.linkStatusChange:info]: HA interconnect: Port ic0a link is down.
[Node1: gop_eq: ic.linkStatusChange:info]: HA interconnect: Port ic0a link is up.
  • 存储故障转移将"可能接管"显示为"false"
Cluster::> storage failover show
                              Takeover
Node           Partner        Possible State Description
Node-01         Node2-02       false Waiting for Node-02, Takeover
                                       is not possible: Storage failover
                             interconnect error, NVRAM log not
                                       synchronized
Node-02         Node-01         false Waiting for Node-01, Takeover
                  synchronized
New to NetApp?
