跳转到主内容
修复了错误 1073579 的系统仍然报告警告消息“ NVRAM Battery current is below normal ( -50mA )( NVRAM 电池电流低于正常值( -50mA ))”
151
Visibility:
Votes:
0
Category:
fas-systems<a>2008261162</a>
Specialty:
hw
Last Updated:
适用场景
  • FAS9000
  • AFF-A700
  • NVRAM 10 FPGA 1.2.0 及更高版本
问题描述
  • 系统正在 运行  错误 1073378的修复版本,但 仍出现相同的症状。
  • 可以通过sysconfig -a控制台在 " " 命令中找到 FPGA 版本,也可以在 ASUP 中检查 "sysconfig-A " :
示例:
slot 6: NVRAM (NVRAM 10)
Revision:           B0
Serial Number:      031945002448
DIMM Size:          16384 MB
Memory Size:        32768 MB
Battery Status:     Battery sufficiently charged
Running Firmware:   1.2.0
  • EMS 日志中的“ Current is below normal (-50 mA) ”警告消息后面出现“ current is normal ”消息,一分钟内显示:
示例:
node-04 ERROR nvram.battery.current.low.warn: The NVRAM battery current is below normal (-50 mA). To prevent data loss, the system will shut down in 24 hours.
node-04 INFORMATIONAL nvram.battery.current.normal: The NVRAM battery current is normal.
node-04 ALERT callhome.battery.warning: Call home for BATTERY (current low) WARNING.
  •  服务处理器( SP )系统事件日志显示以下信息:
示例:
Record 790: Tue Mar 24 12:19:56.369380 2020 [IPMI.notice]: 7b02 | 02 | EVT: 0150ffff | Bat_Curr | Assertion Event, "Lower Non-critical going low " | Reading: -0.050 | Threshold: -0.050
Record 791: Tue Mar 24 12:19:58.174179 2020 [IPMI.notice]: 7c02 | 02 | EVT: 0301ffff | Attn_Sensor1 | Assertion Event, "State Asserted"
Record 792: Tue Mar 24 12:20:27.937336 2020 [IPMI.notice]: 7d02 | 02 | EVT: 6f02ffff | PCM_Status | Assertion Event, "Fault"
Record 793: Tue Mar 24 12:20:32.217038 2020 [IPMI.notice]: 7e02 | 02 | EVT: 6f02ffff | Bat_Status | Assertion Event, "Fault"
Record 794: Tue Mar 24 12:20:32.465387 2020 [IPMI.notice]: 7f02 | 02 | EVT: 815000ff | Bat_Curr | Deassertion Event, "Lower Non-critical going low " | Reading: 0.000 | Threshold: -0.050
Record 795: Tue Mar 24 12:20:39.985458 2020 [IPMI.notice]: 8002 | 02 | EVT: ef02ffff | PCM_Status | Deassertion Event, "Fault"
Record 796: Tue Mar 24 12:20:44.005772 2020 [IPMI.notice]: 8102 | 02 | EVT: ef02ffff | Bat_Status | Deassertion Event, "Fault"
Record 797: Tue Mar 24 12:20:45.997384 2020 [IPMI.notice]: 8202 | 02 | EVT: 0300ffff | Attn_Sensor1 | Assertion Event, "State Deasserted"
New to NetApp?
