跳转到主内容
系统报告使用IOM6和IOM12模块的多路径布线配置下的单路径
76
Visibility:
Votes:
0
Category:
fas-systems<a>multipath</a>
Specialty:
hw
Last Updated:
适用场景
  • ONTAP 9
  • FAS / ASA / AFF平台
  • 支持IOM6/IOM12 堆栈混合
问题描述
  • 为多路径布线时,系统报告单路径。
  • IOM6 和 IOM12 在同一个堆栈中混合使用。
    • 验证兼容性: HWU 。转至 "Storage Limits" (存储限制)>"Full Storage Limit Matrix"(完整存储限制表) >"SupportedsShelts/Driv
  • 如果布线不正确,系统可能会触发类似于以下内容的 EMS 消息:
[Node-01: nchmd: hm.alert.raised:alert]: Alert Id = IOM12ToIOM6SquarePortConnection_Alert , Alerting Resource = 1234567..... raised by monitor node-connect
[Node-01: nchmd: hm.alert.raised:alert]: Alert Id = MixOfIOMAandIOMBConnection_Alert , Alerting Resource = 1234567.....:2 raised by monitor node-connect
[Node-01: nchmd: hm.alert.raised:alert]: Alert Id = SinglePathToDiskShelf_Alert , Alerting Resource = 1234567..... raised by monitor node-connect
  • IOM6 方形端口所连接的端口将被禁用:
Shelf name:   Partner.shelf0
Shelf id:    0
Channel:     Partner
Module:     A
        Partial Path   Link   Invalid   Running    Loss   Phy     CRC    Phy
Disk   Port   Timeout     Rate    DWord   Disparity   Dword   Reset    Error   Change
Id    State   Value (ms)   (Gb/s)   Count   Count     Count   Problem   Count   Count
[SQR0] NO SIGNAL   7      NA     0       0     0     0      0     6
[SQR1] NO SIGNAL   7      NA     0       0     0     0      0     6
[SQR2] NO SIGNAL   7      NA     0       0     0     0      0     6
[SQR3] NO SIGNAL   7      NA     0       0     0     0      0     6
Shelf name:   0b.shelf1
Shelf id:    1
Channel:     0b
Module:     A
[HST8] DIS/ILLGL   7      NA     0       0     0     1      0     4
[HST9] DIS/ILLGL   7      NA     0       0     0     0      0     4
[HST10] DIS/ILLGL   7      NA     0       0     0     1      0     4
[HST11] DIS/ILLGL   7      NA     0       0     0     1      0     4
New to NetApp?
