更换主板后,系统启动失败并显示 "WARNING : 0 disks found" 错误
适用场景
- 更换主板
- 这包括硬件更新
问题描述
- 系统无法 启动并反复重新启动、并显示以下错误:
WARNING: 0 disks found!
Storage Adapters found:
0 Fibre Channel Storage Adapters found!
2 SAS Adapters found!
0 Parallel SCSI Storage Adapters found!
0 ATA Adapters found!
Target Adapters found:
0 Fibre Channel Target Adapters found!
2 iSCSI Target Adapters found!
1 Unknown Target Adapters found!
WARNING: there do not appear to be any disks attached to the system.
Jan 15 18:49:54 [localhost:cf.fm.noMBDisksOrIc:warning]: Could not find the local mailbox disks. Could not determine the firmware state of the partner through the HA interconnect.
No root volume found.
Jan 15 18:49:55 [localhost:zapi.sf.up.ready:info]: ZAPI: system node stable after startup.
Rebooting... (press ctrl-c during boot to break reboot loop)
Uptime: 1m17s
System rebooting...
- 即使在完成主板更换操作步骤后、旧主板仍然是磁盘所有者。
*> disk show -v
Local System ID: 333333333
DISK OWNER POOL SERIAL NUMBER HOME DR HOME CHKSUM
0a.00.8 node-1 (111111111) Pool0 Y5bxxxxxxxxx node-1 (111111111) Block
0b.00.11 node-1 (111111111) Pool0 Y5cxxxxxxxxx node-1 (111111111) Block
0a.00.10 node-1 (111111111) Pool0 Y5dxxxxxxxxx node-1 (111111111) Block
0b.00.3 node-1 (111111111) Pool0 Y5exxxxxxxxx node-1 (111111111) Block
0b.00.9 node-1 (111111111) Pool0 Y5fxxxxxxxxx node-1 (111111111) Block
0b.00.5 node-1 (111111111) Pool0 Y5gxxxxxxxxx node-1 (111111111) Block
