跳转到主内容
Solaris 命令 "cfgadm -c configure" 失败并导致主机 断开与存储的连接
39
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
san
Last Updated:
适用于
  • ONTAP 9
  • Solaris 11
  • Emulex 目标端口
  • FCP
问题
使用 cfgadm -c可能会导致丢失对 ONTAP Emulex 目标端口的 LUN/ 路径访问:
Dec 14 12:49:48 solaris  Failed to create nodes for pwwn=200b00a098efxxxx; error=0x5
Dec 14 12:50:13 solaris scsi: [ID 243001 kern.warning] WARNING: /pci@31e/pci@1/SUNW,emlxs@0/fp@0,0 (fcp0):
Dec 14 12:51:43 solaris genunix: [ID 483743 kern.info] /scsi_vhci/ssd@g600a09803830477364244f63486axxxx (ssd8) multipath status: optimal: path 116 fp0/ssd@w201b00a098efxxxx,63 is offline
 root@solaris:~# cfgadm -c configure c4
cfgadm: Library error: report LUNs failed: 10000090fa02xxxx report LUNs failed: 500a098182eexxxx failed to create device node: 2001005056b1xxxx: I/O er
Operation partially successful. Some failures seen
主机中的扩展 emlxs 日志显示 PRLI 序列超时
 emlxs_msgbuf.out:(PRLI: did=1bf981 Local Reject. Sequence timeout.) [2020 Dec 7 09:42:58:352:475:115] 2636:[4.00F4]emlxs0: DEBUG: 811: Abnormal ELS completion. (PRLI: did=1bfa01 Local Reject. Sequence timeout.)
New to NetApp?
