跳转到主内容
NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
即使实际速度为 1 Gbps , SP 也错误地以 100 Mbps 的速度链接
24
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • 服务访问程序( SP )
  • FAS8300
问题
SP 速度显示 100mb ,而不是 1GB 。
示例:
 NODE::> node run -node NODENAME sysconfig -a NetApp Release 9.7P3: Fri Apr 17 10:40:14 EDT 2020 System ID: xxxxxxxxxx (node1); partner ID: xxxxxxxxxx (node2) System Serial Number: xxxxxxxxxx (node1) System Rev: B1 System Storage Configuration: Multi-Path HA System ACP Connectivity: Inband Active All-Flash Optimized: false Capacity Optimized: false All SAN Array: false Backplane Part Number: 111-04200 Backplane Rev: B0 Backplane Serial Number: xxxxxxxxxx ... Service Processor Status: Online Firmware Version: 13.2 Mgmt MAC Address: xx:xx:xx:xx:xx:xx Ethernet Link: up, 100Mbps <<<<<<< 1Gbps is normal Using DHCP: no
New to NetApp?
Scan to view the article on your device
  • 这篇文章对您有帮助吗?
