跳转到主内容
RTC 电池故障
51
Visibility:
Votes:
0
Category:
fas-systems<a>2008520931</a>
Specialty:
hw
Last Updated:
适用场景
  • FAS/AFF 平台
  • 实时时钟(Real-Time Clock、RTC)币形电池
问题描述
  • 节点和机箱故障 LED 亮起,但没有清晰的故障指示
  • 或者,系统将生成以下 EMS 消息,并报告电池出现非严重故障:
Tue Sep 4 15:05:29 CEST [NODE1:monitor.chassisPower.degraded:warning]: Chassis power is degraded: RTC Battery is in WARN LOW state current voltage is 2774 mV, normal low is 2800 mV
  • SP-LATEST-IPMI log show P3.3v 电池为 []warnlow
P3.3V Batt   warnlow  2660 mV    2537 mV    2695 mV    3307 mV    3447 mV
  • SP-LATEST-SYSLOG log show [rtcWarnLowPower]
BMC env_mgr[1534]: Payload EMS: EMS_monitor_rtcWarnLowPower(2660 mV)
  • BMC events all 显示 P3.3V Batt is critical low
BMC env_mgr[1461]: P3.3V Batt is critical low
  • 在 BMC/SP 中,我们将看到以下非严重情况:
Sensor Name | Current | Unit | Status | LCR | LNC | UNC | UCR -----------------+------------+------------+------------+-----------+-----------+-----------+----------- PCM_Status | 0x0 | discrete | Power Good | na | na | na | na Attn_Sensor1 | 0x0 | discrete | Asserted | na | na | na | na CPU-1_DTS_Temp | -54.000 | degrees C | ok | na | na | -10.000 | 0.000 CPU-2_DTS_Temp | -57.000 | degrees C | ok | na | na | -10.000 | 0.000 CPU0_PVCCP | 1.750 | Volts | ok | 1.580 | 1.670 | 1.920 | 2.010 CPU1_PVCCP | 1.750 | Volts | ok | 1.580 | 1.670 | 1.920 | 2.010 DDR4_PVDDQ_AB | 1.230 | Volts | ok | 1.050 | 1.110 | 1.280 | 1.340 DDR4_PVDDQ_CD | 1.220 | Volts | ok | 1.050 | 1.110 | 1.280 | 1.340 DDR4_PVDDQ_EF | 1.220 | Volts | ok | 1.050 | 1.110 | 1.280 | 1.340 DDR4_PVDDQ_GH | 1.220 | Volts | ok | 1.050 | 1.110 | 1.280 | 1.340 DDR4_PVPP_AB | 2.640 | Volts | ok | 2.300 | 2.440 | 2.800 | 2.940 DDR4_PVPP_CD | 2.600 | Volts | ok | 2.300 | 2.440 | 2.800 | 2.940 DDR4_PVPP_EF | 2.600 | Volts | ok | 2.300 | 2.440 | 2.800 | 2.940 DDR4_PVPP_GH | 2.600 | Volts | ok | 2.300 | 2.440 | 2.800 | 2.940 DDR4_PVTT_AB | 0.610 | Volts | ok | 0.520 | 0.550 | 0.640 | 0.670 DDR4_PVTT_CD | 0.610 | Volts | ok | 0.520 | 0.550 | 0.640 | 0.670 DDR4_PVTT_EF | 0.610 | Volts | ok | 0.520 | 0.550 | 0.640 | 0.670 DDR4_PVTT_GH | 0.610 | Volts | ok | 0.520 | 0.550 | 0.640 | 0.670 DIMM-1-4_Temp | 26.000 | degrees C | ok | 0.000 | 5.000 | 80.000 | 85.000 DIMM-13-16_Temp | 26.000 | degrees C | ok | 0.000 | 5.000 | 80.000 | 85.000 DIMM-5-8_Temp | 26.000 | degrees C | ok | 0.000 | 5.000 | 80.000 | 85.000 DIMM-9-12_Temp | 26.000 | degrees C | ok | 0.000 | 5.000 | 80.000 | 85.000 HotSwap_Current | 29.250 | Amps | ok | 0.000 | 2.000 | 55.000 | 60.000 HotSwap_VOUT | 11.940 | Volts | ok | 10.560 | 11.160 | 12.840 | 13.440 P0V9_SB | 0.900 | Volts | ok | 0.790 | 0.830 | 0.960 | 1.000 P1V2_SB | 1.200 | Volts | ok | 1.050 | 1.110 | 1.280 | 1.340 P1V8_SB | 1.800 | Volts | ok | 1.580 | 1.670 | 1.920 | 2.010 P2V5_SB | 2.500 | Volts | ok | 2.200 | 2.320 | 2.660 | 2.800 P3V3 | 3.280 | Volts | ok | 2.900 | 3.060 | 3.520 | 3.680 P3V3_SB | 3.280 | Volts | ok | 2.900 | 3.060 | 3.520 | 3.680 P3V3_SB_SQ | 3.300 | Volts | ok | 2.900 | 3.060 | 3.520 | 3.680 P3V_BATT | 2.840 | Volts | nc | 2.720 | 2.880 | 3.300 | 3.460
New to NetApp?
