跳转到主内容
扩展器 0 : 11a222 : 333333b : cc 上的一个或多个( 1 ) PHY 处于错误状态
24
Visibility:
Votes:
0
Category:
disk-shelves<a /><a>扩展器上的速率未知 PHY 处于错误状态</a><a>2008863931</a>
Specialty:
hw
Last Updated:
适用场景
  • FAS/AFA系统
  • 磁盘驱动器
问题描述
  • 扩展器上的物理处于错误状态、对于两个SAS路径。示例:
sas.adapter.debug: adapterName="2", debug_string="One or more (1) PHYs on expander 0:11a222:333333b:dd are in a bad state."
sas.adapter.debug: adapterName="7", debug_string="One or more (1) PHYs on expander 0:11a222:444444c:ee are in a bad state."
  • Unknown通过两个SAS路径显示与磁盘相关的一个物理的""状态。示例
::> storage shelf show -instance
    Shelf Name: 5.22
   Stack ID: 5
   Shelf ID: 22
   Shelf UID: 00:11:22:33:44:55:66:77
  Serial Number: SHU0123456A7B8C
   Module Type: IOM6
   Model: DS4246
   Shelf Vendor: NETAPP
    Disk Count: 24
   Connection Type: SAS
   Shelf State: Online
    Status: Normal
 SAS Ports:
       -- Port Speeds Gb/s -- Power  Port
 Phy # IOM Port Type WWPN        Operational Negotiated Status Status
   29  A  Disk    50000c90000948cd      6.0     6.0 on    Enabled
   30  A  Disk    -               -      - -    Unknown
   31  A  Disk    50000c9000095b3d      6.0     6.0 on    Enabled
   29  B  Disk    50000c90000948ce      6.0     6.0 on    Enabled
   30  B  Disk    -               -      - -    Unknown
   31  B  Disk    50000c9000095b3e      6.0     6.0 on    Enabled
  • Rate Uknown该托架磁盘的""状态。示例
::> system node run -node node_name sasstat expander_phy_state 2b.22
                          Pwr
                  Pwr      Ccl      Rsv      Rls
PHY/BAY STATE        ON      Cnt      Cnt      Cnt
30/22  Rate Uknown    YES      13      0      0
  • 磁盘架中的其他磁盘不报告任何问题描述。
New to NetApp?
