跳转到主内容
断电后使聚合脱机
56
Visibility:
Votes:
0
Category:
fas-systems<a>2009210516</a>
Specialty:
hw
Last Updated:
适用场景
  • 所有FAS 和AFF 系统
  • 所有 ONTAP 版本
  • FlashPool
  • 磁盘驱动器X446_PHM2200MCTO、固件低于NA05
  • 磁盘驱动器X438_PHM2400MCTO、固件低于NA05
  • 断电
问题描述
  • 断电后、一个聚合脱机、无法联机
cluster::> storage aggregate modify -aggregate hybrid_aggregate -state online
Error: command failed: Failed to bring aggregate "hybrid_aggregate" online. Reason: Aggregate 'hybrid_aggregate' has failed and cannot be brought online.
  • 聚合的SSD RAID组缺失
Aggregate hybrid_aggregate (failed, mixed_raid_type, partial, hybrid_enabled) (block checksums)
  Plex /hybrid_aggregate/plex0 (offline, failed, inactive)
   RAID group /hybrid_aggregate/plex0/rg0 (normal, block checksums, raid_dp)
    RAID Disk   Device     HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)   Phys (MB/blks)
    dparity    2b.11.4    2b   11  4   SA:B   0   SAS 10000 857000/1755136000 858483/1758174768
    parity     0b.11.5    0b   11  5   SA:A   0   SAS 10000 857000/1755136000 858483/1758174768
    data      2b.11.6    2b   11  6   SA:B   0   SAS 10000 857000/1755136000 858483/1758174768
    data      0b.11.7    0b   11  7   SA:A   0   SAS 10000 857000/1755136000 858483/1758174768
  Plex is missing 1 RAID group.
  • 磁盘X446_PHM2200MCTO显示 Failed-Unsupported 在中 SYSCONFIG-A
11.0 : NETAPP   X446_PHM2200MCTO NA04   0.0GB 0B/sect (Failed-Unsupported)
11.1 : NETAPP   X446_PHM2200MCTO NA04   0.0GB 0B/sect (Failed-Unsupported)
11.2 : NETAPP   X446_PHM2200MCTO NA04   0.0GB 0B/sect (Failed-Unsupported)
11.3 : NETAPP   X446_PHM2200MCTO NA04   0.0GB 0B/sect (Failed-Unsupported)
  • 在发生故障之前、磁盘X446_PHM2200MCTO已打开电源超过70000小时(~8年)
New to NetApp?
