跳转到主内容
Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
由于 "P IPMI failure" ,节点关闭并无法启动
适用场景
  • AFF A700/FAS9000
  • 服务处理器固件版本低于 4.9
问题描述
  • 两个节点均关闭、无法启动
  • 主板已重新就位、但节点停留在LOADER提示符处
  • 节点关闭并显示以下消息:
sp.ipmi.lost.shutdown:EMERGENCY]: SP heartbeat stopped and cannot be recovered. To prevent hardware damage and data loss, the system will shut down in 2 minutes.
  • 可能会出现 AutoSupport
HA Group Notification (SP HBT STOPPED) ALERT
  • 尝试启动时:
Initializing System Memory ...
Loading Device Drivers ...
Waiting for SP ...
IPMI:Enable PCI slots:timeout
SP failure. Resetting SP from primary FW. This can take a few minutes
Waiting for SP ...
SP recovered successfully after a reset from primary FW image
Waiting for SP ...
SP failure. Resetting SP from backup FW. This can take a few minutes
Waiting for SP ...
SP recovered successfully after a reset from backup FW image
Waiting for SP ...
Failed to recover SP
IPMI PCI Slot Control failed.
IPMI PCI Slot Configuration failed.
Configuring Devices ...
IPMI:Get controller FRU inventory:failed
IPMI:Get midplane FRU 0 inventory:failed
IPMI:Get NVRAM FRU inventory:failed
CPU = 2 Processor(s) Detected.
  Intel(R) Xeon(R) CPU E5-2697 v4 @ 2.30GHz (CPU 0)
  CPUID: 0x000406F1. Cores per Processor = 18
  Intel(R) Xeon(R) CPU E5-2697 v4 @ 2.30GHz (CPU 1)
524288 MB System RAM Installed.
SATA (AHCI) Device: SV9MST6D120GLM41NP
Boot Loader version 6.0.12
Copyright (C) 2000-2003 Broadcom Corporation.
Portions Copyright (C) 2002-2021 NetApp, Inc. All Rights Reserved.
BIOS POST Failure(s) detected: SP IPMI failure. Abort AUTOBOOT
New to NetApp?
Scan to view the article on your device
