跳转到主内容
由于多磁盘窗格中缺少一个或多个磁盘架,节点重新启动
54
Visibility:
Votes:
0
Category:
disk-shelves<a>DS4246</a><a>断电</a><a>多磁盘崩溃</a>
Specialty:
hw
Last Updated:
适用场景
  • 所有FAS/AFA系统
  • 磁盘 架
问题描述
  • 磁盘架已关闭。
  • 节点发生故障、并显示多磁盘故障(MDP)和磁盘架电源中断消息:
PANIC: aggr aggr0: raid volfsm, fatal multi-disk error. raid type raid_dp in SK process config_thread on release 8.2.3P4 on Mon Feb 10 07:52:07 CET 2020version: 8.2.3P4: Fri May 29 14:06:54 PDT 2015compile flags: x86_64Writing panic info to HA mailbox disks.HA: current time (in sk_msecs) 128169944521 (in sk_cycles) 299073053244098161CF monitor: takeover will occur on reboot
Mon Feb 10 07:51:19 CET [nodeb: dsa_worker3: callhome_shlf_power_intr_1:error]: params: {'subject': 'SHELF POWER INTERRUPTED'}
  • 控制台日志(而不是崩溃)可能会报告以下内容:
Waiting to be taken over.  REBOOT in 22 seconds.
  • 服务处理器(SP) 事件记录:
Record 2200: Mon Feb 10 01:49:54 2020 [Trap Event.critical]: hwassist abnormal_reboot (28)
  • 如果包含根聚合磁盘(包括邮箱磁盘)的磁盘架脱机、配对节点将无法接管并生成Active IQ警报:
HA Group Notification (PARTNER DOWN, TAKEOVER IMPOSSIBLE ) ERROR
New to NetApp?
