节点崩溃、无法启动并显示错误"未找到设备"
适用场景
问题描述
- 节点未自动启动。
"boot_ontap"
在加载程序中执行后、系统将无法启动并报告以下错误。- 在尝试启动加载程序时、接收类似于以下内容的消息:
LOADER-A> boot_ontap
Could not load fat://boot0/X86_64/freebsd/image1/kernel:Device not found
ERROR: Error booting OS on: 'boot0' file: fat://boot0/X86_64/freebsd/image1/kernel (boot0,fat)
*** command status = Device not found(-6)
LOADER-A> boot_primary
Loading X86_64/freebsd/image1/kernel:Failed: Device not found
Could not load fat://boot0/X86_64/freebsd/image1/kernel: Device not found
LOADER-A> boot_backup
Loading X86_64/freebsd/image2/kernel:Failed: Device not found
Could not load fat://boot0/X86_64/freebsd/image2/kernel: Device not found
Could not load fat://boot0/X86_64/freebsd/image2/kernel:Unknown error
ERROR: Error booting OS on: 'boot0' file: fat://boot0/X86_64/freebsd/image2/kernel (boot0,fat)
*** command status = Unknown error(-62)
Loading X86_64/freebsd/image2/kernel:Failed: Unknown error
Could not load fat://boot0/X86_64/freebsd/image2/kernel: Unknown error
Loading X86_64/freebsd/image1/kernel:Failed: Error
Could not load fat://boot0/X86_64/freebsd/image1/kernel: Error
*** command status = Error(-1)
LOADER-A> boot_recovery
Bootable external device not found!
Boot Recovery failed
- 通过网络启动和安装ONTAP时出现类似错误。示例:
Please choose one of the following:
(7) Install new software first.
Selection (1-9)? 7
super-block backups (for fsck_ffs -b #) at:
192
******* Working on device /dev/ada0 *******
ada0: CAM_CMD_TIMEOUT, retrying (4 retries left)
ada0: CAM_CMD_TIMEOUT, retrying (3 retries left)
Jul 10 15:45:05 [localhost:ata.timeout.retry:notice]: ATA device timeout (ATA TIMEOUT (retrying), Device ada0: (4 retries left)).
Partitioning of boot device complete
Install Failed.
fdisk: invalid fdisk partition table found
fdisk: WARNING: adjusting start offset of partition 1
from 288 to 315, to fall on a head boundary
fdisk: WARNING: adjusting size of partition 1 from 33554016 to 33553989
to end on a cylinder boundary
fdisk: Failed to write MBR. Try to use gpart(8).
newfs_msdos: /dev/ada0s1: No such file or directory
ERROR: Unable to create a filesystem on the boot device.
umount: /mnt: not a file system root directory
