跳转到主内容
运行 boot_ontap 时,节点将启动至维护模式
105
Visibility:
Votes:
0
Category:
fas-systems<a>2008774362</a>
Specialty:
hw
Last Updated:
适用场景
  • ONTAP 9
  • Data ONTAP 8
问题描述
  • boot_ontap 从加载程序提示符运行时、节点始终会启动到维护模式。
  • 此时将显示以下消息:
NOTE: You have chosen to boot the diagnostics kernel.
The system has booted in maintenance mode allowing the
Use the 'sldiag' command in order to run diagnostics on the system.
New to NetApp?
