跳转到主内容
NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
在 ONTAP 升级过程中,多个标记为预故障的 X438_1625400 MCSG 驱动器
20
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • ONTAP 8.3P2
  • ONTAP 9.1 P20
  • x438_1625400 MCSG 驱动器
问题
在执行 ONTAP 升级后的一段时间内,几个 X438_1625400 MCSG 驱动器会连续短时间发生故障。
消息表明驱动器在升级过程中预出现故障:
Tue May 05 17:07:12 CEST [NETAPP-N2: config_thread: raid.disk.predictiveFailure:warning]: Disk 0a.00.2 Shelf 0 Bay 2 [NETAPP X438_1625400MCSG NA04] S/N [S182NEAG123456] reported a predictive failure and it is prefailed; it will be copied to a spare and failed
Tue May 05 17:07:12 CEST [NETAPP-N2: config_thread: raid.disk.predictiveFailure:warning]: Disk 0a.00.1 Shelf 0 Bay 1 [NETAPP X438_1625400MCSG NA04] S/N [S182NEAG234567] reported a predictive failure and it is prefailed; it will be copied to a spare and failed
Tue May 05 17:07:12 CEST [NETAPP-N2: config_thread: raid.disk.predictiveFailure:warning]: Disk 0a.00.3 Shelf 0 Bay 3 [NETAPP X438_1625400MCSG NA04] S/N [S182NEAG345678] reported a predictive failure and it is prefailed; it will be copied to a spare and failed
New to NetApp?
Scan to view the article on your device
