跳转到主内容
中板 3 和中板 4 温度警告为高
4
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
服务处理器 (SP)
问题
中板 3 和中板 4 温度警告为高,因为中存在以下错误。 EMS
示例:
Mar 11 01:06:12 +0900 [node_name: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Midplane 4 Temp is warning high (47 C).
Mar 11 01:06:12 +0900 [node_name: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Midplane 3 Temp is warning high (47 C).
Mar 11 01:07:13 +0900 [node_name: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
CPU0 温度边距传感器状态显示为 init-failedPLATFORM-SENSORS的。
示例:
Sensor Name: CPU0 Temp Margin
Sensor Type: thermal
Sensor State: init-failed
Last Sensor Value:
Value Units: C
Warning Hi Threshold: 0
Critical Hi Threshold: -1
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
