跳转到主内容
由于系统ID冲突、MetroCluster 配置失败
35
Visibility:
Votes:
0
Category:
metrocluster
Specialty:
metrocluster<a>2008666813</a><a>进行翻译</a>
Last Updated:
适用场景
  • MetroCluster 配置
  • FAS 系统
  • ONTAP 9
问题描述
MetroCluster 配置将失败、请注意:
CLUSTER::> metrocluster configure [Job 259] Configuring Clusters[Job 259] Job failed: Configure command failed on node "NODE-1" in the local cluster. Reason: (Local node's system id in the nodelist does not match the NVRAM system id). Check the hardware for errors and make sure all remote nodes are online, then try the command again with "-refresh true". Use the "metrocluster operation show" command to view detailed error information. Resolve the errors, then try the command again.
New to NetApp?
