跳转到主内容
由于表CCMA_数据 存储库中的密钥重复、无法生成性能归档
66
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf<a>perfarchive</a><a>CCMA_dataStore</a>
Last Updated:
适用场景
  • ONTAP 9
  • 性能归档:PerfArchive
问题描述
调用PerfArchives后显示以下警告:
Warning: Unable to list entries on node node_name. Loop detected in next() for table ccma_datastore. Next on "node_name vldb opm" return "node_name cmd"
示例:
Node::*> autosupport invoke-performance-archive -node * -start-date "5/18/2020 06:10:00" -duration 4h -uri "file:///mroot/etc/log/autosupport/perfarchive.7z"
The AutoSupport was successfully invoked on node "Node-N1" (sequence number: 502).
The AutoSupport was successfully invoked on node "Node-N2" (sequence number: 531).
The AutoSupport was successfully invoked on node "Node-N3" (sequence number: 66).
The AutoSupport was successfully invoked on node "Node-N4" (sequence number: 64).
Warning: Unable to list entries on node Node-N4. Loop detected in next() for table ccma_datastore. Next on "Node-N4 vldb opm" returned "Node-N4 cmd ".
New to NetApp?
