集群端口上发生大量 CRC 错误
适用于
- FAS 2750
- ONTAP 9
问题
- 使用的 e0b 端口上的 CRC 错误计数为 1212 次
ifconfig:
-- interface e0b (232 days, 2 hours, 21 minutes, 3 seconds) --
RECEIVE
Total frames: 252m | Frames/second: 13 | Total bytes: 39644m
Bytes/second: 1977 | Total errors: 1218 | Errors/minute: 0
Total discards: 0 | Discards/minute: 0 | Multi/broadcast: 1020k
Non-primary u/c: 0 | CRC errors: 1212 | Runt frames: 0
Fragment: 0 | Long frames: 0 | Jabber: 3
Length errors: 3 | No buffer: 0 | Xon: 0
Xoff: 0 | Pause: 0 | Jumbo: 1293k
Noproto: 0 | Error symbol: 236 | Illegal symbol: 199
Bus overruns: 0 | Queue drops: 0 | LRO segments: 249m
LRO bytes: 26713m
| LRO6 segments: 0 | LRO6 bytes: 0
Bad UDP cksum: 0 | Bad UDP6 cksum: 0 | Bad TCP cksum: 0
Bad TCP6 cksum: 0 | Mcast v6 solicit: 0
TRANSMIT
Total frames: 561m | Frames/second: 28 | Total bytes: 139g
Bytes/second: 6980 | Total errors: 0 | Errors/minute: 0
Total discards: 0 | Queue overflow: 0 | Multi/broadcast: 1031k
Xon: 0 | Xoff: 0 | Pause: 0
Jumbo: 2565k | Cfg Up to Downs: 2 | TSO non-TCP drop: 0
Split hdr drop: 0 | Timeout: 0 | TSO segments: 402k
TSO bytes: 4840m | TSO6 segments: 0 | TSO6 bytes: 0
HW UDP cksums: 154k | HW UDP6 cksums: 0 | HW TCP cksums: 556m
HW TCP6 cksums: 0 | Mcast v6 solicit: 0
DEVICE
Mcast addresses: 3 | Rx MBuf Sz: 4096
LINK INFO
Speed: 10000M | Duplex: full | Flowcontrol: none
Media state: activ
e | Up to downs: 8
- EMS 错误消息每小时持续提供以下输出:
Tue Dec 01 04:04:26 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
Tue Dec 01 05:04:27 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
Tue Dec 01 06:04:27 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
Tue Dec 01 07:04:27 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
Tue Dec 01 08:04:28 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
Tue Dec 01 09:04:29 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
- 即使在作为隔离更换 HA 配对控制器 e0b 端口之间的 SAS 缆线后,上述错误消息也不会停止。
k-tenant-str::> event log show
Time Node Severity Event
1/5/2021 15:11:21 node 2 ERROR netif.linkErrors: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicat
1/5/2021 14:54:52 node 1 EMERGENCY vifmgr.clus.linkdown: The cluster port e0b on node node 1 has gone down unexpectedly.
1/5/2021 14:54:52 node 2 EMERGENCY vifmgr.clus.linkdown: The cluster port e0b on node node 2 has gone down unexpectedly.
1/5/2021 14:11:20 node 2 ERROR netif.linkErrors: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
1/5/2021 13:11:20 node 2 ERROR netif.linkErrors: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
1/5/2021 12:11:19 node 2 ERROR netif.linkErrors: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port,
Press <space> to page down, <return> for next line, or 'q' to quit... q
6 entries were displayed.
- 更换缆线前后, CRC 错误计数不会增加。
- 此设备为无交换机集群配置,目标 e0b 端口是一个端口,可将节点 1 作为集群 LIF 端口直接连接到节点 2 。
- 连接到速度和双工的每个节点之间的端口没有区别,也不使用 SFP 等收发器。
