跳转到主内容
带内 ACP 报告“正在初始化”、“固件 - 需要更新”或“不支持” IOM 6 模块
75
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
适用场景
  • 带内备用控制路径( ACP )
  • IOM6 模块
  • ONTAP 9.x
问题描述
  • 在 ONTAP 9.x 中、带内 ACP 是默认配置。
  • ACP 模块可能会报告以下内容而不是活动的内容:
    • initializing
    • firmware-update-required
    • unsupported
  • ACP 状态显示在 EMS 日志中(状态发生初始更改时):
Mon Aug 05 10:07:15 CEST [CLUSTER-01: dsa_worker1: ses.status.ACPWarn:error]: DS4246 (S/N SHFxxxxxxxxxxxx) shelf 1 on channel 0a ACP Processor warning for SAS shelf ACP processor 1: ACP status not available. Element in transition mode. This module is on the rear of the shelf at the top center, on shelf module A.
Mon Aug 05 10:07:16 CEST [CLUSTER-01: sem_broker: acp.need.firmware.update:error]: ACP module  (NA) needs a firmware upgrade, (disk shelf serial number: SHFxxxxxxxxxxxx).
  • 可以使用以下命令随时检查状态:
::> storage shelf acp module show -fields protocol-version ,firmware-version ,state,module-name,iom-type ,shelf-serial-number
node      module-name protocol-version firmware-version shelf-serial-number iom-type state
CLUSTER-01  1.01.A    0.0.0.0      0.0        SHFxxxxxxxxxxxx    iom6    firmware-update-required
CLUSTER-01  1.01.B    0.0.0.0      0.0        SHFxxxxxxxxxxxx    iom6    firmware-update-required
CLUSTER-01  1.02.A    0.0.0.0      0.0        SHFxxxxxxxxxxxx    iom6    unsupported
CLUSTER-01  1.02.B    0.0.0.0      0.0        SHFxxxxxxxxxxxx    iom6    unsupported
::> system node run -node * -command acpadmin ibacp_list_all
Node: CLUSTER-01
Number of ACP modules 2
MAC         SES   Last Contact  Protocol   Assigner   Shelf        Current Inband   IOM    shelf
Address       bit   (seconds ago) Version   ACPA ID    S/N         State   ID     Type   flag
00:a0:98:xx:xx:xx  00    6780     1.2.02.10   0       SHFxxxxxxxxxxxx   0x9   0a.01.A IOM6    0x20
00:a0:98:xx:xx:xx  00    1432     1.2.02.10   0       SHFxxxxxxxxxxxx   0x9   0b.01.B IOM6    0x20
00:a0:98:xx:xx:xx  00    4452     1.2.02.10   0       SHFxxxxxxxxxxxx   0xe   0a.02.A IOM6    0x20
00:a0:98:xx:xx:xx  01    1121     1.2.02.10   0       SHFxxxxxxxxxxxx   0xe   0b.02.B IOM6    0x20
  • 在 AutoSupport 的存储模块 .xml 和 ACP-IBACCP-list (所有部分)中可以分别找到相同的信息。
New to NetApp?
