带内 ACP 报告“正在初始化”、“固件 - 需要更新”或“不支持” IOM 6 模块
适用于
- 带内备用控制路径( ACP )
- IOM 6 模块
- ONTAP 9.x
问题
- 在 ONTAP 9.x 中、带内 ACP 是默认配置。
- ACP 模块可能会报告以下内容而不是活动的内容:
initializing
firmware-update-required
unsupported
- ACP 状态显示在 EMS 日志中(状态发生初始更改时):
Mon Aug 05 10:07:15 CEST [CLUSTER-01: dsa_worker1: ses.status.ACPWarn:error]: DS4246 (S/N SHFxxxxxxxxxxxx) shelf 1 on channel 0a ACP Processor warning for SAS shelf ACP processor 1: ACP status not available. Element in transition mode. This module is on the rear of the shelf at the top center, on shelf module A.
Mon Aug 05 10:07:16 CEST [CLUSTER-01: sem_broker: acp.need.firmware.update:error]: ACP module (NA) needs a firmware upgrade, (disk shelf serial number: SHFxxxxxxxxxxxx).
- 可以使用以下命令随时检查状态:
::> storage shelf acp module show -fields protocol-version ,firmware-version ,state,module-name,iom-type ,shelf-serial-number
node module-name protocol-version firmware-version shelf-serial-number iom-type state
CLUSTER-01 1.01.A 0.0.0.0 0.0 SHFxxxxxxxxxxxx iom6 firmware-update-required
CLUSTER-01 1.01.B 0.0.0.0 0.0 SHFxxxxxxxxxxxx iom6 firmware-update-required
CLUSTER-01 1.02.A 0.0.0.0 0.0 SHFxxxxxxxxxxxx iom6 unsupported
CLUSTER-01 1.02.B 0.0.0.0 0.0 SHFxxxxxxxxxxxx iom6 unsupported
::> system node run -node * -command acpadmin ibacp_list_all
Node: CLUSTER-01
Number of ACP modules 2
MAC SES Last Contact Protocol Assigner Shelf Current Inband IOM shelf
Address bit (seconds ago) Version ACPA ID S/N State ID Type flag
00:a0:98:xx:xx:xx 00 6780 1.2.02.10 0 SHFxxxxxxxxxxxx 0x9 0a.01.A IOM6 0x20
00:a0:98:xx:xx:xx 00 1432 1.2.02.10 0 SHFxxxxxxxxxxxx 0x9 0b.01.B IOM6 0x20
00:a0:98:xx:xx:xx 00 4452 1.2.02.10 0 SHFxxxxxxxxxxxx 0xe 0a.02.A IOM6 0x20
00:a0:98:xx:xx:xx 01 1121 1.2.02.10 0 SHFxxxxxxxxxxxx 0xe 0b.02.B IOM6 0x20
- 在 AutoSupport 的存储模块 .xml 和 ACP-IBACCP-list (所有部分)中可以分别找到相同的信息。
