跳转到主内容
NX5596 上的 ISL 端口可能出现故障
10
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
network
Last Updated:
适用场景
  • ONTAP 9
  • Cisco NX5596 集群网络交换机
  • 支持的 NX-OS 和 RCF 版本
问题描述
system health alert show 输出中存在以下错误:
The cable used to connect switch "switch(sn#) /Ethernet1/41" to the ISL port might be faulty. For the port-channel, please check each individual link.
The cable used to connect switch "switch(sn#)/Ethernet1/42" to the ISL port might be faulty. For the port-channel, please check each individual link.
The cable used to connect switch "switch(sn#) /Ethernet1/43" to the ISL port might be faulty. For the port-channel, please check each individual link.
The cable used to connect switch "switch(sn#)/Ethernet1/44" to the ISL port might be faulty. For the port-channel, please check each individual link.
New to NetApp?
