警告:《系统解决指南》中似乎没有任何磁盘已连接
适用场景
- AFF系统
- FAS 系统
- ONTAP 9
- 存储
问题描述
尝试启动AFF或FAS系统时、可能会显示以下消息:
WARNING: 0 disks found!
Storage Adapters found:
2 Fibre Channel Storage Adapters found!
4 SAS Adapters found!
0 Parallel SCSI Storage Adapters found!
0 ATA Adapters found!
Select option 4 from the boot menu to choose disks for the root volume and spare core space.
Target Adapters found:
2 Fibre Channel Target Adapters found!
0 iSCSI Target Adapters found!
WARNING: there do not appear to be any disks attached to the system.
No root volume found.
Rebooting... (press ctrl-c during boot to break reboot loop)
