跳转到主内容
Flash Cache 停留在重新恢复阶段,但不会 接受插入
64
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf<a>性能</a><a>闪存缓存</a><a /><a>1164008</a><a>闪存</a><a>重新恢复</a>
Last Updated:
适用场景
ONTAP 9.3P8 及更早版本
问题描述
Flash Cache 停留在重新恢复阶段,不接受插入,并出现以下症状:
  • 磁盘层延迟较高
  • 磁盘利用率高
  • Flash Cache 中的缓存插入 / 命中率较低
要确认 Flash Cache 中的缓存插入 / 命中率较低,请执行以下操作:
示例:
cluster::> set advanced
Warning: These advanced commands are potentially dangerous; use them only when directed to do so by NetApp personnel.
Do you want to continue? {y|n}: y
cluster::*> statistics start -sample-id <test1> -object ext_cache_obj -counter inserts|hit_percent|rewarm_aggrs_failed
Statistics collection is being started for sample-id: test1
fas8200-2n-dal-1::*> statistics stop -sample-id <test1>
Statistics collection is being stopped for sample-id: test1
fas8200-2n-dal-1::*> statistics show -sample-id <test1>
Object: ext_cache_obj
Instance: ec0
Start-time: 5/18/2021 10:43:17
End-time: 5/18/2021 10:43:25
Elapsed-time: 8s
Scope: cluster-1a
   Counter                            Value
  hit_percent                           0%
  inserts                              0
Instance: ec0
Elapsed-time: 8s
Scope: cluster-1b
   Counter                            Value
  hit_percent                           0%
  inserts                              0
4 entries were displayed.
注:
  • hit_percent 应为 0% ,表示无缓存命中
  • inserts 应低于 10/s ,表示 Flash Cache 中未插入任何数据
New to NetApp?
