磁盘存储架上报告故障:缺少缆线信息
适用场景
- ONTAP 9
问题描述
EMS-LOG-FILE
AutoSupport 部分:
Wed Jun 24 01:00:00 CEST [NETAPP_01: statd: monitor.shelf.warning:error]: Fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
ENVIRONMENT
AutoSupport 部分 缺少缆线信息
Channel: 0b Shelf: 0 SAS cable information by element: [1] Internal connector [2] Vendor: Amphenol Type: MINI-SAS HD passive copper 5m ID: 01 Swaps: 0 Serial number: APF16330153087 Part number: 112-00437 A0 [3] Internal connector [4] Vendor: Type: <N/A><N/A><N/A> ID: 00 Swaps: 0 Serial number: Part number: <==== cable information missing
- 重新拔插相应的控制器模块后,问题描述 仍会保留
- 磁盘架固件为最新版本
