跳转到主内容
BIOS 升级错误:无法将主映像保存到备份闪存设备
1,157
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • AFF A300
  • AFF A320
  • AFF A200
  • AFF A220
  • AFF A700s
  • FAS 8200
  • BIOS 更新
    • 手动
    • ANDU
问题
  • 从 ONTAP 手动/ANDU 更新 BIOS 固件失败并停止到LOADER提示。
New BIOS version: 11.15
New LOADER version: 6.0.14
Enabling write access to the flash ME region...
ME region - write access enabled.
Saving Primary Image to Backup flash device
fail unlocking memory
Failed. -4 bytes written: I/O error
Failed to save Primary Image to Backup flash device. Programming of Primary aborted
Automatic firmware update skipped (update_flash command failed).
Warning: The boot media contains a newer firmware image (11.15).
Please run 'update_flash' at the Loader prompt to update your
system firmware (11.11).
---------.+**** Flash verify failed. ****
*** command status = I/O error(-4)
  • 如果执行自动无中断升级 (ANDU),升级将暂停,因为合作伙伴is not in a "waiting for giveback
::> cluster image show-update-progress
                       Estimated      Elapsed
Update Phase      Status           Duration     Duration
Pre-update checks   completed         00:10:00     00:00:35
Data ONTAP updates   paused-on-error      01:23:00     00:37:18
Details:
Node name       Status       Status Description
node-01      waiting
node-02      failed       Error: Node "node-02" is not in
                    "waiting for giveback" state.
                    Action: Use the "storage failover
                    show" to verify that node
                    "node-02" is in one of the
                    following states: "waiting for
                    giveback" or "connected".
  • 从 SP 执行 system power cycle 无法解决此问题。
New to NetApp?
