跳转到主内容
FCP目标适配器显示链路已断开
123
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
san
Last Updated:
适用场景
  • ONTAP 9
  • FCP
问题描述
  • 事件日志条目表示FC链路已断开连接:
5/23/2020 21:11:31  cluster-node1  ERROR scsitarget.ispfct.linkBreak: Link break detected on Fibre Channel target adapter 1b. Firmware status code status1 0x2, status2 0x7, and status4 0x0.
  • sysconfg -a 将端口状态报告为Link Disconnected""
slot 1: Fibre Channel Target Host Adapter 1b (QLogic 8324 (8362) rev. 2, <LINK DISCONNECTED>) Board Name: QLE2672 Serial Number: RFE2005W04482 Firmware rev: 8.9.0 Flash rev: 1.1.2 Host Port Addr: 000000 FC Nodename: xx:0a:09:80:80:xx:xy:xx (500a098080b3a125) FC Portname: xx:0a:09:82:80:xy:yy:xx (500a098280b3a125) Connection: No link Switch Port: Unknown SFP Vendor Name: FINISAR CORP. SFP Vendor P/N: FTLF8529P4BCV-QM SFP Vendor Rev: B SFP Serial No.: P2SABCS SFP Connector: LC
  • 0.0 (uWatts)  FCP-Adapter.xml ASUP中的日志显示了光纤通道目标适配器的Rx和Tx功率:
Rx : 0.0 (uWatts)
Tx : 0.0 (uWatts)
  • Network fcp adapter show 在命令行界面上执行的命令会将运行状态报告为"link disconnected"
cluster::> network fcp adapter show
           Connection  Port    Admin   Operational
Node      Adapter Established Address   Status  Status
cluster-node1
       0c    false     0      up    link not connected
cluster-node1
       0d    false     0      up    link not connected
cluster-node1
       1a      true     f0500    up    online
cluster-node1
       1b    true     0      up    link disconnected
cluster-node2
cluster-node2
cluster-node2
       1a    true     f0600    up      online
cluster-node2
       1b    true     f0600    up    online
  • 存储HBA端口仍以物理方式连接
尝试隔离问题描述的以下故障诊断步骤:
  • 已 使用以下命令验证远程SFP的运行状况并已退回端口:
Cisco示例:
switch# config terminal
switch(config)# interface fc <slot>/<port#>
switch(config)# show int fc <slot>/<port#> transceiver detail
switch(config-if)# shutdown
switch(config-if)# no shutdown
Brocade示例:
switch:admin> sfpshow <index # OR slot/port #>
switch:admin> portdisable <index # OR slot/port #>
switch:admin> portenable <index # OR slot/port #>
  • 已执行物理检查并重新安装连杆和 配线板部件。
  • 重新安装后、重复端口弹跳过程。
  • 更换/交换两端的组件、包括缆线和SFP。
New to NetApp?
