跳转到主内容
FCP 适配器报告 "scsitarget.hwfct.mserr" 错误,原因代码为 0x9 和 和 EMS 中的响应代码 0x8001
58
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
san
Last Updated:
适用场景
  • ONTAP 9
  • FAS系列
问题描述
EMS日志显示 scsitarget.hwpfct.mserr 错误、原因代码为 0x9、 响应代码为0x8001
 示例:
[Node-01: fct_tpd_work_thread_0: scsitarget.hwpfct.mserr:debug]: The Fibre Channel fabric management server request (GID_PT) sent from adapter 0e failed with reason code 0x9 (Server unable to perform operation), explanation code 0xa (Port type not registered), and response code 0x8001.
[Node-01: fct_tpd_work_thread_0: scsitarget.hwpfct.mserr:debug]: The Fibre Channel fabric management server request (GID_PT) sent from adapter 0f failed with reason code 0x9 (Server unable to perform operation), explanation code 0xa (Port type not registered), and response code 0x8001.
[Node-01: fct_tpd_work_thread_0: scsitarget.hwpfct.mserr:debug]: The Fibre Channel fabric management server request (GA_NXT) sent from adapter 0e failed with reason code 0x9 (Server unable to perform operation), explanation code 0x1 (Port id not registered), and response code 0x8001.
New to NetApp?
