跳转到主内容
FAS80x0多个风扇出现故障
532
Visibility:
Votes:
0
Category:
fas-systems<a>2008586830</a>
Specialty:
hw
Last Updated:
适用场景
  • FAS8060
  • FAS8040
问题描述
  • 多个系统风扇出现故障。
  • EMS.log 显示 。
[?] Fri Dec 18 14:54:02 KST [node: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan1 F1
[?] Fri Dec 18 14:54:02 KST [node: env_mgr: monitor.chassisFan.stop:alert]: Chassis fan contains at least one stopped fan: SysFan1 F1 (failed)
[?] Fri Dec 18 14:54:02 KST [node: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan1 F2
[?] Fri Dec 18 14:54:02 KST [node: env_mgr: monitor.chassisFan.stop:alert]: Chassis fan contains at least one stopped fan: SysFan1 F2 (failed)
[?] Fri Dec 18 14:54:02 KST [node: env_mgr: monitor.chassisFanFail.xMinShutdown:EMERGENCY]: Multiple Chassis Fan failure: System will shut down in 2 minutes.
[?] Fri Dec 18 14:54:16 KST [node: config_thread: raid.aggr.log.CP.count:debug]: params: {'aggregate_uuid': '0x7f14c792-401cfb6b-f2b4e0bf-4a66d2ac', 'CP_count': '9208063', 'aggregate_type': 'Aggregate', 'home_owner_name': 'node', 'home_owner_id': '537132046', 'aggregate_name': 'node_aggr0'}
[?] Fri Dec 18 14:54:20 KST [node: dsa_vmm: hamsg.connectSucceeded:debug]: params: {'remoteID': '66d64da6b0c111e68de8254a945fa7e2'}
[?] Fri Dec 18 14:54:32 KST [node: env_mgr: callhome.c.fan.fru.shut:error]: Call home for MULTIPLE CHASSIS FAN FAILED: System will shut down in 2 minutes
[?] Fri Dec 18 14:54:39 KST [node: vldb: rdb.ha.verified:notice]: Verified that cluster high availability (HA) is configured correctly, and that on-disk mailboxes are intact.
[?] Fri Dec 18 14:55:00 KST [node: monitor: monitor.globalStatus.critical:critical]: Multiple fans failed: Sysfan1 F2, Sysfan1 F1.
[?] Fri Dec 18 14:55:25 KST [node: dsa_vmm: hamsg.connectSucceeded:debug]: params: {'remoteID': '66d64da6b0c111e68de8254a945fa7e2'}
[?] Fri Dec 18 14:56:32 KST [node: statd: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Multiple fans failed)
New to NetApp?
