跳转到主内容
外付けシェルフのないシングルパスHAで動作するFAS500fまたはAFF-A250コントローラ
27
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
環境
  • AFF-A250、AFF-C250、ASA-A250、ASA-C250
  • FAS500f
問題
外付けディスクシェルフのない新しいAFF A250、AFF C250、ASA A250、ASA C250、またはFAS500fストレージシステムをセットアップするときに、 Single-Path HAsysconfig -a または storage show disk -p ノードシェルからシステムがモードで動作していることがあります
。例:
NetApp Release 9.8P1: Wed Jan 20 20:14:09 EST 2021 System ID: xxxxxxxxxxx (xxxxxxxxxxx); partner ID: xxxxxxxxxx (xxxxxxxxxxxxxx) System Serial Number: xxxxxxxxxxxx(xxxxxxxxxxx) System Rev: A3 System Storage Configuration: Single-Path HA System ACP Connectivity: Inband Active SAS2/SAS3 Mixed Stack Support: none All-Flash Optimized: true Capacity Optimized: false All SAN Array: false Backplane Part Number: 111-04891+A0 Backplane Serial Number: xxxxxxxxxxxxxxxx slot 0: System Board 2.1 GHz (System Board XXVIII A3) Model Name: FAS500f Part Number: 111-04585 Revision: A3 Serial Number: xxxxxxxxxxxxxxxx BIOS version: 17.1 Loader version: 6.5.1 Processors: 12 Processor ID: 0x50654 Microcode Version: 0x2006906 Processor type: Intel(R) Xeon(R) D-2164IT CPU @ 2.10GHz Memory Size: 65408 MB Memory Attributes: Node Interleaving Hoisting Rank Interleaving Chipkill ECC NVMEM Size: 8188 MB of Main Memory Used Controller: B PCIE Switch 0: id 0 705 1.00 PCIE Switch 1: id 1 705 2.00 TPM FW Version: 5.63.3353.0 Service Processor Status: Online Firmware Version: 15.1P1 Mgmt MAC Address: xxxxxxxxxxxxxxxx Ethernet Link: up, 1Gbps Using DHCP: no IPv4 configuration: IP Address: x.x.x.x Netmask: x.x.x.x Gateway: x.x.x.x IPv6 configuration: Disabled slot 0: Virtual NVMe Host Adapter 0n 0 : NETAPP X4020S173A15TNQF NA51 14651.0GB 4160B/sect (xxxxxxxxxxxxxx) 1 : NETAPP X4020S173A15TNQF NA51 14651.0GB 4160B/sect (xxxxxxxxxxxxxx) 2 : NETAPP X4020S173A15TNQF NA51 14651.0GB 4160B/sect (xxxxxxxxxxxxxx) <SNIP> 21 : NETAPP X4020S173A15TNQF NA51 14651.0GB 4160B/sect (xxxxxxxxxxxxxx) 22 : NETAPP X4020S173A15TNQF NA51 14651.0GB 4160B/sect (xxxxxxxxxxxxxx) 23 : NETAPP X4020S173A15TNQF NA51 14651.0GB 4160B/sect (xxxxxxxxxxxxxx) Shelf 0: NS224NSM8E Firmware rev. NSM8E A: 0101 NSM8E B: 0101 <SNIP> slot 1: 100G Ethernet Controller CX6-Mezz e1a MAC Address: xxxxxxxxxxxxxx (auto-unknown-fd-down) e1b MAC Address: xxxxxxxxxxxxxx (auto-unknown-fd-down) Device Type: CX6 PSID(NAP0000000013) Firmware Version: 20.28.1002 Part Number: 111-04588 Hardware Revision: A0 Serial Number: xxxxxxxxxxxxxx
New to NetApp?
