跳转到主内容
由于断电, FAS2750 停机
18
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用场景
  • FAS2750
  • ONTAP 9
  • 两个机箱 PSU 的 LED 状态均为绿色
问题描述
  • 断电后,一个节点不会恢复联机
  • system health alert show 指出 PSU2 问题描述
cluster::> system health alert show
Node: node_02
Resource: sn# 12345
Severity: Critical
Indication Time: Thu Dec 30 16:53:25 2021
Suppress: false
Acknowledge: false
Probable Cause: PSU2 FRU is off. The nodes in this chassis are
node_02, node_01.
Possible Effect: The system might switch off if the other redundant
power supply units (PSUs) become faulty.
Corrective Actions: 1. Check PSU2 FRU and switch it on.
2. Refer to the Hardware specification guide for more information on the position of the power supply unit (PSU) and ways to check or replace it.
New to NetApp?
