FAS2650崩溃重新启动
适用场景
- FAS2650
- FAS2720
问题描述
下面的FS2650因崩溃而重新启动。
PANIC : PCI Error NMI from device(s):RPT(0,1,0):PLX PCIE 8725 switch on Controller.
version: 9.3: Thu Jan 4 03:00:09 PST 2018
conf : x86_64.optimize
cpuid = 3
Uptime: 1064d21h2m38s
fpudna: fpcurthread == curthread
PANIC: PCI Error NMI from device(s):RPT(0,1,0):PLX PCIE 8725 switch on Controller. in process idle: cpu3 on release 9.3 (C) on Tue Feb 9 17:01:40 JST 2021
compile flags: x86_64.optimize
HA: current time (in sk_msecs) 92005240804 (in sk_cycles) 174404934374763539
DUMPCORE: START
Dumping to disks: 0b.00.23P1
DUMPCORE: END -- coredump written
coredump: compression ms 39164 compressions 12624 bytes in 34107015168 bytes out 8665915679 ratio 393%
comp BW 830MB/s
coredump: write ms 50496 write count 2258 write bytes 8666017792 write BW 163MB/s
coredump: total ms 150138 chunks of all zeroes 383
System rebooting...
Flash Cache NVMe固件版本在sysconfig-A中显示了ERRORMOD
slot 1: Flash Cache NVMe
Serial Number: XXXXXXXXXXXXXX
Part Number: XXX-XXXXX
Hardware Revision: A0
Firmware Version: ERRORMOD
Model Name: X3310A
Capacity: 512 GB
Vendor Name: Samsung
State: ok
