跳转到主内容
FAS2552 或 FAS2554 会忽略连接到的不受支持的设备 boot_i 默认启动设备端口
94
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
适用于
  • ONTAP 9
  • FAS2552
  • FAS2554
  • X1425A-R6 (固件版本 141031 )
  • SP1425D-R6 (备用部件号)
问题
  • 使用启动设备部件号 X1425A-R6 的启动顺序示例:
IPsec: Initialized Security Association Processing.
Ignoring unsupported device boot_i attached to the default bootdevice port.
Boot Loader version 4.3
Copyright (C) 2000-2003 Broadcom Corporation.
Portions Copyright (C) 2002-2014 NetApp, Inc. All Rights Reserved.
CPU Type: Intel(R) Xeon(R) CPU C3528 @ 1.73GHz
Starting AUTOBOOT press Ctrl-C to abort...
File not found (errcode=-18)
diskinfo: /dev/da0: No such file or directory
ERROR: Unable to read diskinfo from device /dev/da0.
umount: /mnt: not a file system root directory
 What is the URL for the package? http://192.168.0.2/95P7_q_nodar_image.tgz What is the user name on "192.168.0.2", if any? Checking network link... success. Checking route to host "192.168.0.2"... success. Attempting to reach 192.168.0.2... success. Looking up URL "http://192.168.0.2/95P7_q_nodar_image.tgz"... success. Computed package size is 1461M Using ramdisk size of 1461M Downloading package... success. Checking package contents... success. Extracting install script from package... success. Invoking script (validation phase). INSTALL running in check-only mode: the image will be validated only Mode of operation is INSTALL Current image is image1 Alternate image is image2 Using device /dev/da0 for install Package MD5 checksums pass Versions are compatible Install Validation Failed. diskinfo: /dev/da0: No such file or directory ERROR: Unable to read diskinfo from device /dev/da0. umount: /mnt: not a file system root directory
New to NetApp?
