跳转到主内容
紧急关闭:在 FAS8700 中,环境原因关闭(电池未充电)已终止
16
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
FAS8700
问题
在系统日志中可以看到以下消息
[node:monitor.globalStatus.critical:EMERGENCY]: Disk shelf fault.
Jan 06 17:12:53 [node:callhome.battery.failure:EMERGENCY]: Call
home for BATTERY (no charge) CRITICAL.
Jan 06 17:31:53 [node:monitor.shutdown.emergency:EMERGENCY]:
Emergency shutdown: Environmental Reason Shutdown (Battery not charging)
Terminated
Uptime: 204d2h0m56s
System powering down...
Jan 06 20:25:14 [node:nvmem.battery.noCharge:ALERT]: The NVMEM
battery is requesting to be charged but the charger is not charging the
battery. To prevent data loss, the system will shut down in 20 minutes.
Jan 06 20:25:41 Battery charge capacity: 1200 mA*hr. Power outage protection
flash de-staging cycles: 14
WARNING:  The battery is experiencing a critical failure:
           - Failed to charge the battery
          Without a working battery, the system cannot retain data
          during a power outage, which can result in data loss.
          Power down the system and verify that the battery is
          properly installed.
          To ignore this failure and boot the system in a mode
          where data loss might occur, press 'c' followed by 'Enter'
Jan 06 20:26:14 [node:callhome.battery.failure:EMERGENCY]: Call
Jan 06 20:27:43 Battery charge capacity: 1200 mA*hr. Power outage protection
Jan 06 20:29:45 Battery charge capacity: 1200 mA*hr. Power outage protection
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
