EMS 日志报告 env_mgr: monitor.temp.unreadable: 控制器温度 (****) 不可读
适用于
- ONTAP 9
- AFF 系统
- ASA 系统
- FAS 系统
问题
- 控制器无法读取温度传感器报告。
- EMS 日志报告以下事件。
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Module B Expander Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Module A Expander Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 4 Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 3 Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 2 Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 1 Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Ambient Temp) is not readable.
[env_mgr: monitor.chassisPower.degraded:warning]: Chassis power is degraded: Sensor detecting voltage anomalies.
monitor.temp.unreadable: monitor.temp.unreadable: The controller temperature (Mezz Temp2) is not readable
[monitor.temp.unreadable:error]: The controller temperature (PCISW-3 Die Temp) is not readable.
[monitor.temp.unreadable:error]: The controller temperature (PCISW-4 Die Temp) is not readable.
[monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high..
Chassis temperature is too high..EMS 可能会因传感器损坏而报告以下内容
Feb 18 10:18:19 [netapp01-06:callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
SP-LATEST-IPMI可能会报告控制器传感器failed的状态:
PCISW-3 Die Temp failed -- C 0 C 5 C 90 C 100 C
PCISW-4 Die Temp failed -- C 0 C 5 C 90 C 100 C
