EMS日志报告env_mgr:monitor.temp.unreadable:控制器温度("**")不可读
适用场景
- FAS
- AFF
问题描述
- 控制器无法读取温度传感器报告。
- EMS日志报告以下事件。
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Module B Expander Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Module A Expander Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 4 Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 3 Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 2 Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 1 Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Ambient Temp) is not readable.
[env_mgr: monitor.chassisPower.degraded:warning]: Chassis power is degraded: Sensor detecting voltage anomalies.
monitor.temp.unreadable: monitor.temp.unreadable: The controller temperature (Mezz Temp2) is not readable
