跳转到主内容
NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
EMS 日志每 1 小时报告一次 iomem.nor.op.failed:critical" 错误
23
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • FAS8060
  • ONTAP 8.2.1
问题
  • EMS 日志每 1 小时报告一次 iomem.nor.op.failed:critical" 错误。
示例:
[?] Wed Sep 09 18:47:13 JST [filer: fmm_main: iomem.nor.op.failed:critical]: params: {'slot': '3', 'part_num': '111-00903', 'reason': 'Interface timeout', 'address': '0x20000', 'model': 'X1974A-R6', 'serial': 'xxxxxxxxx', 'op': 'Erase'}
[?] Wed Sep 09 18:47:13 JST [filer: fmm_main: fmm.dev.stats.write.failed:debug]: Flash Cache in slot 3: Error occured while writing a statistics copy onboard the device at index 1.
[?] Wed Sep 09 19:47:18 JST [filer: fmm_main: iomem.nor.op.failed:critical]: params: {'slot': '3', 'part_num': '111-00903', 'reason': 'Interface timeout', 'address': '0x20000', 'model': 'X1974A-R6', 'serial': 'xxxxxxxxx', 'op': 'Erase'}
[?] Wed Sep 09 19:47:18 JST [filer: fmm_main: fmm.dev.stats.write.failed:debug]: Flash Cache in slot 3: Error occured while writing a statistics copy onboard the device at index 1.
  • Flash Cache 将保持联机状态。
              slot 3: Flash Cache 2 (1.0 TB)
               State:     Enabled
          Model Name:     X1974A-R6
       Serial Number:     xxxxxxxxx
         Part Number:     111-00903
      Board Revision:     C2
        FPGA Release:     3.4
          FPGA Build:     201407151914
New to NetApp?
Scan to view the article on your device
  • 这篇文章对您有帮助吗?
