跳转到主内容
nodeshell中的聚合重复、而clustershell中的聚合不重复
2
Visibility:
Votes:
0
Category:
fas-systems<a>2009260832</a>
Specialty:
core
Last Updated:
适用场景
  • ONTAP 9
问题描述
  • nodeshell报告聚合出现故障、该聚合与系统上现有运行状况良好的聚合重复。
  • 此不正确的聚合与附加了(1)的正确聚合名称相同。不正确的聚合显示为故障、并由一个磁盘以及可能还有其他未同化的孤立磁盘组成。
示例:
 Aggregate n01_aggr1(1) (failed, mixed_raid_type, partial, hybrid_enabled) (block checksums) Plex /n01_aggr1(1)/plex0 (offline, failed, inactive) RAID group /n01_aggr1(1)/plex0/rg5 (partial, block checksums, raid_dp) RAID Disk Device HA SHELF BAY CHAN Pool Type RPM Used (MB/blks) Phys (MB/blks) --------- ------ ------------- ---- ---- ---- ----- -------------- -------------- dparity FAILED N/A 1695466/ - parity FAILED N/A 1695466/ - data FAILED N/A 1695466/ - data FAILED N/A 1695466/ - data FAILED N/A 1695466/ - data FAILED N/A 1695466/ - data FAILED N/A 1695466/ - data FAILED N/A 1695466/ - data FAILED N/A 1695466/ - data 3b.12.17 3b 12 17 SA:B 0 BSAS 7200 1695466/3472315904 1695759/3472914816 data FAILED N/A 1695466/ - data FAILED N/A 1695466/ - data FAILED N/A 1695466/ - data FAILED N/A 1695466/ - Raid group is missing 13 disks. Plex is missing 11 RAID groups. Unassimilated n01_aggr1(1) disks RAID Disk Device HA SHELF BAY CHAN Pool Type RPM Used (MB/blks) Phys (MB/blks) --------- ------ ------------- ---- ---- ---- ----- -------------- -------------- orphaned 3b.12.9 3b 12 9 SA:B 0 BSAS 7200 1695466/3472315904 1695759/3472914816 orphaned 3b.13.1 3b 13 1 SA:B 0 BSAS 7200 1695466/3472315904 1695759/3472914816
  • Vreport还会显示差异。
示例:
对象类型聚合
对象N01_aggr1 (xxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx)
节点名称:节点01
聚合UUID:<xxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxxxxxx>
聚合状态:故障
聚合RAID状态:混合RAID_type、部分、混合启用的
聚合HA策略:SFO
为聚合根: false
是复合聚合:仅
WAFL 中存在差异的原因为false
New to NetApp?
