跳转到主内容
磁盘架 DS460C 报告温度过低( UTE )警告警报
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
适用场景
DS460C 存储架
问题描述
磁盘架 DS460C 会报告 UT 警告警报,一段时间后,此警告将自动更正
示例:
 Fri Jan 14 12:16:38 KST [node: dsa_worker0: ses.status.temperatureWarning:alert]: DS460-12 (S/N XXXXXX) shelf 20 on channel 0b temperature warning for Temperature sensor 2: non-critical status. Current temperature: 9 C (48 F). This module is on the rear of the shelf at the top middle inside of the PSU 1 inlet. Fri Jan 14 12:16:47 KST [node: statd: monitor.shelf.warning:error]: Fault reported on disk storage shelf attached to channel 0b. Check fans, power supplies, disks, and temperature sensors. Fri Jan 14 12:16:47 KST [node: statd: callhome.shlf.fault:error]: Call home for SHELF_FAULT
 Temperature Sensors: Element Status Status Bytes Status Descriptions 1: OK 01,00,2A,00 2: NONCRITICAL 03,00,1D,01 UT WARNING 3: OK 01,00,35,00 4: OK 01,00,32,00 5: OK 01,00,2B,00 6: OK 01,00,34,00 7: OK 01,00,31,00 8: OK 01,00,35,00 9: OK 01,00,33,00
New to NetApp?
