磁盘在 "sysconfig - r" 中保持 " 测试 " 状态
适用于
- ONTAP 9
- FAS8200
问题
- 磁盘将在磁盘 0d.10.3 和维护池中开始测试。
EMS 日志示例:
Thu Feb 20 03:54:54 JST [node-02: config_thread : raid.disk.maint.start:notice ]:Disk 0d.10.3 Shelf 10 Bay 3 [NETAPP X343_SSKBE1T8A10 NA01] S/N XXXXXXXX] UID
[5000C500:C144C6DF:00000000:00000000]will be tested.
- 经过一段时间后、“
sysconfig -r
”仍处于维护状态、但已通过“sysconfig -a
”确认、磁盘处于故障状态。
“sysconfig -a
”和“sysconfig -r
”示例:
・ sysconfig - a
NetApp Release 9.5P6: Wed Jul 10 19:00:56 EDT 2019
System ID: XXXXXXXXXX (node-02); partner ID: XXXXXXXXXX (node-01)
System Serial Number: XXXXXXXXXXXX (node-02)
slot 0: SAS Host Adapter 0a (PMC-Sierra PM8072 rev. C, SAS, <UP>)
10.3 : NETAPP X343_SSKBE1T8A10 NA01 1713.5GB 520B/sect (XXXXXXXX) (Failed)
slot 0: SAS Host Adapter 0d (PMC-Sierra PM8072 rev. C, SAS, <UP>)
・ sysconfig – r
Maintenance disks
RAID Disk Device HA SHELF BAY CHAN Pool Type RPM Used (MB/blks) Phys (MB/blks)
testing 0a.10.3 0a 10 3 SA:B 0 SAS 10000 1713523/3509295616 1716957/3516328368 (fast zeroed)
