跳转到主内容
磁盘驱动器故障 LED 指示灯不正确地亮起而不会出现任何硬件故障
340
Visibility:
Votes:
1
Category:
fas-systems<a>ONTAP 9</a>
Specialty:
hw
Last Updated:
状态信息
适用场景
  • ONTAP 9.6P3 及更低版本
  • 所有磁盘型号
问题描述
  • 磁盘驱动器故障LED (稳定琥珀色)未正确打开、未发生任何硬件故障
  • 更换故障磁盘后、磁盘仍保持琥珀色指示灯亮起
  • sysconfig -a 命令 sysconfig -r 显示硬件状态为正常
示例:
sysconfig -a
 slot 0: SAS Host Adapter 0a (PMC-Sierra PM8070 rev. C, SAS, <UP>)
  Firmware rev:       03.08.09.00
  Base WWN:           5:00a098:00b0d93:30
  Phy State:          [0] Enabled, 12.0 Gb/s
                      [1] Enabled, 12.0 Gb/s
                      [2] Enabled, 12.0 Gb/s
                      [3] Enabled, 12.0 Gb/s
  Mini-SAS HD Vendor:        Amphenol
  Mini-SAS HD Part Number:   X66031A+A0
  Mini-SAS HD Type:          Passive Copper (unequalized) 0.5m ID:00
  Mini-SAS HD Serial Number: APF18179087711
                01.19: NETAPP   X343_TA14E1T8A10 NA01 1713.5GB 520B/sect (88P0A1QRF09D)
                01.20: NETAPP   X343_STBTE1T8A10 NA02 1713.5GB 520B/sect (W3Z16F99)
                01.21: NETAPP   X343_TA14E1T8A10 NA01 1713.5GB 520B/sect (88P0A1V0F09D)
                01.22: NETAPP   X343_HCBFE1T8A10 NA02 1713.5GB 520B/sect (08G3RZLZ)
                01.23: NETAPP   X343_TA14E1T8A10 NA01 1713.5GB 520B/sect (88P0A1YBF09D)
sysconfig -r
Pool1 spare disks (empty)
Pool0 spare disks
RAID Disk Device  HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
Spare disks for block checksum
spare   0a.01.20 0a    1   20  SA:A   0   SAS 10000 1713523/3509295616 1716957/3516328368
spare   0a.01.22 0a    1   22  SA:A   0   SAS 10000 1713523/3509295616 1716957/3516328368
spare   0a.02.23 0a    2   23  SA:A   0   SAS 10000 1713523/3509295616 1716957/3516328368
New to NetApp?
