跳转到主内容
Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
在sysconfig-A中检测到磁盘、但在sysconfig-r中检测到磁盘在更换后失败
适用场景
  • Data ONTAP 8 7-模式
  • 磁盘资格审批包( DKP )
问题描述
  • 磁盘出现故障并已更换。在 sysconfig -a 输出中列出。示例:
3.14: NETAPP   X318_HARHE08TA07 NA00 7486.1GB 520B/sect (VKJ1M9PX)
  • 更换的磁盘将作为备用磁盘列出、而不会在RAID组中进行更换。示例:
Pool0 spare disks
    RAID Disk   Device    HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)   Phys (MB/blks)
   spare     0b.03.14  0b   3   14  SA:B   0   SAS 15000 7486157/15331651072 7501160/15362376264
Aggregate aggr4 (online, raid_dp, degraded) (block checksums)
    Plex /aggr4/plex0 (online, normal, active)
      RAID group /aggr4/plex0/rg0 (normal, block checksums)
     RAID group /aggr4/plex0/rg1 (degraded, block checksums)
       parity   0b.03.13   0b   3   13  SA:B   0  FSAS  7200 7486157/15331651072 7501160/15362376264
      data    FAILED       N/A             7486157/ -
       data    0b.03.15   0b   3   15  SA:B   0  FSAS  7200 7486157/15331651072
  • DQP已过时或未安装。示例:
Disk Qualification Package Details:
    Package Date:  Unable to load any package (Package version not supported)
   Header Information
      FileName   = N/A
     FileVersion = N/A
     DriveRecordCount = N/A
     AliasRecordCount = N/A
     DeviceRecordCount = N/A
     SystemRecordCount = N/A
New to NetApp?
Scan to view the article on your device
