跳转到主内容
由于同一故障域中的单路径或路径、磁盘分配失败
260
Visibility:
Votes:
0
Category:
disk-drives<a>FAS</a><a>磁盘分配</a>
Specialty:
hw
Last Updated:
适用场景
  • FAS / AFF 型号
  • ONTAP 9
问题描述
  • 手动分配未分配的磁盘失败、并显示以下消息
NetApp-Cluster::*> storage disk assign -disk 1.1.2 -owner NetApp-01
Error: command failed: Failed to assign disks. Reason: Disk 1.1.2 is not assigned because it either has less than two paths or all its paths are connected to the same fault domain. Correct the configuration error or specify the -force option. For more details, use the "storage errors show" command.
New to NetApp?
