跳转到主内容
在ONTAP中禁用BMC的IPv4/IPv6 IP无法正常工作并显示错误
25
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
适用场景
  • AFF A400
  • FAS 8700
  • FAS 8300
  • FAS 2820
问题描述
从ONTAP禁用BMC的IPv4/IPv6不起作用、并显示错误以启用IPv6/IPv4、即使已同时启用IPv4和IPv6也是如此。
::> sp network modify -node node1 -address-family IPv4 -enable false
Error: command failed: IPv4 address can be disabled only if IPv6 address is enabled.
::> sp network modify -node node1 -address-family IPv6 -enable false
Error: command failed: IPv6 address can be disabled only if IPv4 address is enabled.
New to NetApp?
