由于端口映射程序故障, Data ONTAP API 失败
适用场景
- FAS2552
- FAS2554
问题描述
电源重置后, SP 日志中会显示一个错误,如下所示:
示例:
Jan 1 00:00:33 1970 [IPMI.notice]: 9f02 | c0 | OEM: ffff7000ff00 | ManufId: 150300 | SP Power Reset
Jan 1 00:00:33 1970 [IPMI.notice]: a002 | c0 | OEM: fcff70560000 | ManufId: 150300 | POS Register: Power on Reset(Normal Power Cycle)
Jan 1 00:00:37 1970 [IPMI.notice]: a102 | 02 | EVT: 0157ff88 | SASS_1.2V | Assertion Event, "Upper Non-critical going high"
Jan 1 00:00:37 1970 [IPMI.notice]: a202 | 02 | EVT: 0159ff8e | SASS_1.2V | Assertion Event, "Upper Critical going high"
Jan 1 00:00:38 1970 [IPMI.notice]: a302 | 02 | EVT: 0301ffff | Power_Good | Assertion Event, "State Asserted"
Jan 1 00:00:38 1970 [IPMI.notice]: a402 | 02 | EVT: 0301ffff | Power_Proc_OK | Assertion Event, "State Asserted"
Jan 1 00:00:38 1970 [IPMI.notice]: a502 | 02 | EVT: 6fc201ff | System_FW_Status | Assertion Event, "Memory initialization"
Jan 1 00:00:38 1970 [IPMI.notice]: a602 | 02 | EVT: 0301ffff | Controller_Fault | Assertion Event, "State Asserted"
Jan 1 00:00:42 1970 [IPMI.notice]: a702 | 02 | EVT: 81597c8e | SASS_1.2V | Deassertion Event, "Upper Critical going high"
Jan 1 00:00:42 1970 [IPMI.notice]: a802 | 02 | EVT: 81577c88 | SASS_1.2V | Deassertion Event, "Upper Non-critical going high"
Nov 27 23:05:37 2020 [BIOS.notice]: BIOS time adjust: Set SP time. Old and new time are the same: Fri Nov 27 23:05:37 2020.
Nov 27 23:05:37 2020 [BIOS.notice]: BIOS time adjust: Set SP time. Old time: Thu Jan 1 00:00:46 1970. New time: Fri Nov 27 23:05:37 2020.
Nov 27 23:05:38 2020 [IPMI.notice]: a902 | 02 | EVT: 6fc004ff | System_FW_Status | Assertion Event, "Unrecoverable system-board failure"
