从 BMC 重置后,BMC 日志中缺少 DIMM 事件
适用于
- AFF
问题描述
- 在基于 SP/BMC 的重置后,可以在 'bmc status -d' 命令的输出中观察到以下消息:
Mar 16 17:29:37 BMC IPMIMain[1110]: [1110 : 1305 INFO]BBSP is 0x1f (BIOS Starting)... Previous BBSP value was: 0x2f Mar 16 17:29:37 BMC IPMIMain[1110]: [1110 : 1305 INFO]Watchdog Disabled Mar 16 17:29:37 BMC IPMIMain[1110]: [1110 : 1305 INFO]Restoring Thresholds and Hysteresis Mar 16 17:29:37 BMC IPMIMain[1110]: [1110 : 1305 INFO]SP Based Restart
Mar 16 17:31:20 BMC hsam[1487]: HSAM OS(ontap):cmd(clr) FLD(/chassis-1/controller-b/dimm-1):fault(DIMM Missing) Mar 16 17:31:20 BMC hsam[1487]: HSAM OS(ontap):cmd(clr) FLD(/chassis-1/controller-b/dimm-1):fault(Incorrect DIMM in slot) Mar 16 17:31:20 BMC hsam[1487]: HSAM OS(ontap):cmd(clr) FLD(/chassis-1/controller-b/dimm-1):fault(DIMM Disabled) Mar 16 17:31:20 BMC hsam[1487]: HSAM OS(ontap):cmd(clr) FLD(/chassis-1/controller-b/dimm-2):fault(DIMM Missing)
