跳转到主内容
Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
AFF A400 , FAS8300 或 FAS8700 上的 CriticalFruNotPresentAlert
15
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • ONTAP 9
  • AFF A400
  • FAS8300
  • FAS8700
问题
  • CriticalFruNotPresentAlert 针对风扇模块报告:
Alert ID: CriticalFruNotPresentAlert:Fan4 is not present in the chassis 01212341211
Node: netapp-01
Monitor: chassis
Alerting Resource: Fan4#123456789000
Subsystem: Environment
Indication Time: Fri SEP 18 23:20:06 2020
Perceived Severity: Critical
Probable Cause: Configuration_error
Description:
Fan4 is not present in the chassis 01212341211. The nodes in this chassis are netapp-01
Corrective Actions:
1. Plug in Fan4 correctly into the slot.
2. Refer to the Hardware specification guide for more information on the position of the field-replaceable unit (FRU)
3. Contact support personnel if the alert persists.
Possible Effect:
The nodes in the chassis might not function effectively or redundancy might be lost.
Acknowledge: false
Suppress: false
Policy: CriticalFruNotPresentAlertPolicy
Acknowledger: -
Suppressor: -
Additional Information: Serial No of the FRU: Fan4#123456789000
  • 除以外,所有风扇传感器均显示风扇正常工作 有关 FRU 信息,请查看
Fan4 FRU INFO    discrete    failed
  • BMC 传感器会将 FRU ID 显示为不可读
FRU Device Description : Fan4_FRU (ID 8)
Unknown FRU header version 0xff
New to NetApp?
Scan to view the article on your device
  • 这篇文章对您有帮助吗?
