控制器无法启动,并显示错误 "Detected FIPS-certed Encrypting disk x.x.x"
适用场景
- FAS
- AFF
- ONTAP 9
- FIPS 驱动器
- NSE 驱动器
问题描述
- 启动ONTAP 后、所有驱动器均显示FAILED。
- 例如、在启动到维护模式后
sysconfig -v
、如下所示:
slot 0: SAS Host Adapter 0a (PMC-Sierra PM8070 rev. C, SAS, <UP>)
Firmware rev: 03.08.09.00
Base WWN: 5:00a098:0038a6d:30
Phy State: [0] Enabled, 12.0 Gb/s
[1] Enabled, 12.0 Gb/s
[2] Enabled, 12.0 Gb/s
[3] Enabled, 12.0 Gb/s
Mini-SAS HD Vendor: Amphenol
Mini-SAS HD Part Number: 112-00435+A0
Mini-SAS HD Type: Passive Copper (unequalized) 0.5m ID:01
Mini-SAS HD Serial Number: APF16454005221
ID Vendor Model FW Size
00.0 : NETAPP X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
00.1 : NETAPP X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
00.2 : NETAPP X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
00.3 : NETAPP X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
00.4 : NETAPP X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
00.5 : NETAPP X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
00.6 : NETAPP X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
00.7 : NETAPP X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
00.8 : NETAPP X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
00.9 : NETAPP X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
00.10: NETAPP X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
00.11: NETAPP X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
- 启动时,将显示以下消息:
Dec 01 14:34:15 [localhost:disk.encryptNoSupport:error]: Detected FIPS-certified encrypting disk 0b.00.3, but bootarg.storageencryption.support indicates that FIPS disks should not be present. 24 of 24 disks checked are FIPS disks.
- 如果已配置HA、则系统可以继续启动、直到
Waiting for giveback:
Waiting for giveback...(Press Ctrl-C to abort wait)Entering FM state:5 because mbFound:0 local in headswap:0
